keeping my system
acura cl
13
miami
hey i was wondering whats the less stealable or jackable box to put my subs and amp in??? like is fiberglass good and harder to steal? or all the same? and what are some of the things i can do to help like make it less stealable, or take more time to steal, any help will do, and no i dont mean by putting an alarm,i mean like when im installing what else can i do to help keep it in my trunk, instead of someone elses....
thanks
I would go with what ever box material you would like.
Something I have done in the past is to fasten the box and amps to the trunk floor with "L" brackets and use a screw or bolt that would require something more than a wrench or a flat-head or phillips.
I used screws that required a square headed screw driver. but there are other styles out there. ( hex, allen,.....)
Or you could build the system 'inside' your vehicle. Meaning you would fabricate the enclosure, amp rack, and whatever else you wanted to the exact measurements for your trunk space. It is a lot harder but it would make stealing the system very time consuming. The best way for someone not to steal it is to not to be able to remove it. The 'L bracket and other screws' post is also a deterrent but it is easier to remove than if the whole enclosure is a part of the car! Use your imagination and get creative with it. Once you have the system designed and installed you still might want to get something to slow down stealing the whole vehicle though! Good luck~//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i have one of those lowjacks in my sub box. i also bolted the box down from the inside. i drilld out 2 1/2" holes and used 2 1/2" bolts. the use a crap load of silacone and some of that foam stuff from home depot to keep it from losing and air through the bolt holes. the bolt end on the out side is the rounded/flat side. the only way to get my box out, is by removing the subs first. the subs r in there with 5" wood sreews that have a hex-star shaped head that i have coverd with soder. i takes me over an hour to remove my system, and thats WITH power tools! my radio in a pioneer with the built in DFS alarm that plays really loud high pitch sounds though my tweeters and mids. i have a clerion alarm in my hatch, and another one under my hood. i have a kill switch for my fule pump and my alarm is hooked up to my cars computer. (kill switches r NO GOOD if hooked up to the ignition. (all that dose is keep them from using your key hole(with most thefes dont use n e ways)).
i hoped i helped you out a little
if you can get into your car 1 way, then there is like 5 other ways somone else can.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
466
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
904
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
936
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
acura cl
acura cl
miami
ChopShop Racing
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
