That's right, boys and girls. Corporal Kenwood has another one for you. She's a bit rough cosmetically but operationally everything's A-OK //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Need a good, reliable 4 channel amp on a budget? Lookie what I've got ready-to-go for $90/shipped anywhere in the lower 48:
Kenwood KAC-846 4/3/2-channel amp.
50w X 4 @ 4 Ohm stereo
75w X 4 @ 2 Ohm stereo
150w X 2 @ 4 Ohm mono bridged
50~200Hz HP crossover(12dB/octave)
50~200Hz LP crossover (12dB/octave) (these are independently adjustable for front and rear...or 'A' and 'B'... channels)
Will do 4-channel output on a 2-channel input so could make a good amp for active on low-ish power.
On my bench it made clean output on all four channels using a newly acquired CDA-7875 for a source.
All original screws are intact and there is no sloppiness in the pots for the crossover adjustments. The slide controls for various functions still make positive contact with the detents that are applicable to them. Last but (not) least the LED in the triangle on the 'W' on the KENWOOD logo across the front still shines brightly.
C'mon and get it! You know what Prowler says is up regarding his For Sale threads is the real deal.
And here she is:
And here she is:
