K I'm bored of my 13w6v2 already...
Alright guys, I'm trusting you on this, I'm gonna try to build a ported box to save money and try it out. Do you guys think I should build it to JL specs? or tune it a little lower..
I think the JL spec's are tuned at 34 hz.
Uhh... the more ports, the more space needed... so, either your box is tuned wrong or you were mis-informed.
Correct, but with dual square ports on the sides, I have the added room needed to accomodate them. With the single slot port, there was no room to have the slot above or below the 13" sub, and I didn't want just one slot to one side. Looks asymetrical. So We split it and went with two ports, one on either side, where volume was not an issue.
Go with JL spec. The specs for their boxes maximize what their subs are intended to do. If you want to go lower, then a sub designed to be better at lower frequencies may be what you want.
As others have said, try ported. If you like the SQ from the W6, ported will increase the out put. If it doesn't increase it "enough" for your tastes, then I guess you'll need a different sub.
i did sealed for about 4 years, now i am doing ported and man, what a difference it makes. IT POUNDS, and honestly i dont think it sounds any worse than before. the subs themselves react differently. almost as if they can breath now where before they were being strangled.
Is this with the setup in your sig? Or did you have experience with the w6's?
The problem might not be the sub...
what's up front?
Up front I have a pair of JL VR 650-CSI's, and a pair of Boston acoustics s95 6x9's in the rear powered by an alpine MRP-F450, I'm more then happy with my speakers, and I don't think that's the issue, I just want more thump in my sub-stage...
I previously had a type r sealed but it had virtually no SQ to it... I guess I shouldn't be comparing a type r to a w6 and expect the same output lol.. I might just be too used to the R
Subst4nce
Subst4nce
Long Island
Subst4nce
