just ordered my 12 inch sx....
WMStateChamp18
this is my box design is it gona work good or do you guys think i should change it?
Net Volume: 2.5 cubic feet
Tuning Frequency: 33 Hz
Port Width: 4.25 inches
Port Area: 61.625 Square Inches
Port Length: 54.5 inches
External Dimensions: 34 wide x 16 tall x 19.75 deep.
Board Dimensions and Quantity
Color Count Width Height
Top and Bottom 2 34 inches 19.75 inches
Red 1 29 inches 14.5 inches
Yellow 1 19 inches 14.5 inches
Black 1 32.5 inches 14.5 inches
Green 1 19.75 inches 14.5 inches
Teal 2 14 inches 14.5 inches
Violet 1 13.5 inches 14.5 inches
Number of 49x97 Sheets of 3/4" MDF: 0.75
here is one at 33hz 2.5 cu ft with 60sq inches of port
http://www.caraudio.com/vb/private.php?do=showpm&pmid=372690
and that is a pic of the box design
just comment if u want and help if u wana also thanks!
how can i put that pic on here then
Save it and rehost it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif....
You're in Columbus? **** I was just there this weekend, we drove around showing off my setup //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
You'll enjoy the SX man!
NG
it says that the ends should be diffrent lenghts is that wrong one is the yellow which is 19 inch and the other green is 19.75 inch is that wrong or whats goingon tehre anyone konw anything why it owuld be liek that or should they be the same?
well i did not konw if i had to wire it a special way to get the sub and amp to 1 ohm thats why!
Do it that way WILL be wiring the Dual 2ohm voice coils in parallel, making your amplifier see a 1ohm load //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
NG
MDF is .75" long so the side probably fits agianst the 19.75 and on top of the 19 //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
WMStateChamp18
WMStateChamp18
Columbus, OH
WMStateChamp18
