just got my 6.5 comps installed
airtas
NY
as the title says i just got my 6.5 comps installed a few questions it seems that the tweeters sounds louder than the coaxils is it supposed to be that way?
if i turn up my speakers real loud then it evens out........is it mainly vocal that come out of the tweets? how do i make more sound out of the mids?
A coaxial is a tweeter and a midrange in the same unit; Sharing the same axis, thereby coaxial.
If you have a coaxial and a tweeter on both sides, you're running four tweeters and that would be why.
If you have a component set, the "speaker" is only a midwoofer, and does not have an integrated tweeter.
Most likely, you've attached the tweeter to a portion of your crossover that isn't [as] attenuated; Or, maybe you have some additional boost on your headunit; BBE, DSO?
A coaxial is a tweeter and a midrange in the same unit; Sharing the same axis, thereby coaxial.If you have a coaxial and a tweeter on both sides, you're running four tweeters and that would be why.
my mistake it isnt a coaxil on the door it is the tweeter on the dash and the speaker on the door panel
what do you mean by this attenuation?
3 : to lessen the amount, force, magnitude, or value of : WEAKEN4 : to reduce the severity, virulence, or vitality of
intransitive senses : to become thin, fine, or less
i think it was pretty much plug and play the crossover didnt have any options
airtas
airtas
NY
Trancer
