Just got a DMM...need some help
Raisedin305
Banned
OK. Im running an orion 2500d amplifier with two 15" Kicker L7s DVC 4. I know orion is already a little too powerful for these subs so I want to set the gains properly. I dont understand how I get the voltage that I want. For example I only want to give these subs about 1000watts rms or a little more (1100). How can I achieve this running them @1ohm? Im running stock eletrical system. 130amp alt and a 630 cca battery. Can anybody give me the number that I need to set the DMM to read and how you got that number? Thanks
if you want to send 1000 watts to the subs at 1 ohm, look for the AC voltage of 32 volts. With an amp of that caliber, I'd give it a little more juice... say 1500. In that case, set the voltage to 39 volts. It's your call.
1500 to L7s when the rms is 1000? I already blew them running at .5 ohm. I dont want it to happen again. I just want it to be loud and reliable.
clearly you lack the knowledge to run them properly. Read the gain setting tutorial in the Amplifier forum.
Raisedin305
Banned
Raisedin305
Miami,FL
Raisedin305
