DarkFox
Also... just want to throw in my 2 cents here. I, whenever possable, prefer to run subs off the same amp. I do this becuase:
1. No Phase matching
2. No line matching
3 No voltage or "gain" matching
4. As they age, you wont have to adjust all over again as the amps wear
I would just run them on a XX-Colossus II. You can wire the subs together for a 2ohm load, be getting 3200W to the pair. I mean 1600W a piece is nice, not overloading them TOO much. If you push as much power to them as you are thinking then if they blow, they might do so in such a way that overpowering is apperent and voids your warranty. Plus the amp will only cost you 750. If you have money to spair, and you can easily replace the sub, then overpower them as much as you want. I wouldnt go much more then what I said though. All IMO of coarse though. Dont forget to send me a link when you build your box either!
2. No line matching
