paikiah 5,000+ posts
Wangaholic
Jmac, you've given me dimensions on this before, but I lost the printout so I need you help again... was hoping that you could help me out here...
I was about to purchase some HX2's with RF amps, but due to circumstances, I can't afford any parts except sheets of MDF...so please, help me out here, k? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I previously had a sealed box, 1.509Cu.Ft. for two RFP1810 and now want to have a slot port box...
I have an underpowered amp pushing the two 8 ohm 10"subs, so I'd need something that don't need a bucketload of power ot push the cones... oh, and I'm more for SQ than SPL...
Erm, the shape might, again, look funny (i.e., not rectangular) so I'm just gonna have to tell you the biggest size I can manage after 2 sub displacements as well as the ports... about 1.8~2.0Cu.Ft... the specs for the subs are as follows:
RFP-1810
Nominal Diameter 10" (254mm)
Magnet Weight 30oz (850.5g)
Frequency Range 25-500Hz
Nom Imppedance 8ohms
DC resistance(RE) 7.2ohms
fs 26Hz
Qms 4.7
Qes 0.29
Qts 0.27
Sd 54.26"Sq. (0.035sq.M)
Vas 2.72Cu.Ft (77L)
Cms 4.97E-04
Mms 3.1394oz (89g)
VC Dia 2" (50.6mm)
VC Winding height 1" (25.4mm)
VC Former Material 5 mil aluminium
VC Inductance 4mH
Bl 18.2Tm
Xmax 0.31" (8mm)
Sensitivity (SPL) 88dB
PE 200W RMS
rec box vol 0.75Cu.Ft
Speaker Displacement 0.06Cu.Ft
powered by
Amp: RF 60.2
Dynamic power rating @4ohm mono 14.4v 270watts (Dynamic meaning PMPO?)
RMS @4ohm mono 13.8v 120watts
yes, I've heard from at least 1394861526587 people that my amps are underpowered...I also get drastically underpaid...
Jmac, please help me out..I'm in a terrible mood these days (from the disappoint of not being able to get the pair of HX2's...)//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i wanna make a box to comfort myself...
RFP-1810
fs 26Hz
Qms 4.7
Qes 0.29
Qts 0.27
Vas 2.72Cu.Ft (77L)
Cms 4.97E-04
Mms 3.1394oz (89g)
VC Dia 2" (50.6mm)
VC Inductance 4mH
Bl 18.2Tm
Xmax 0.31" (8mm)
PE 200W RMS
powered by
Amp: RF 60.2
