JL WO 12-4ohm -vs- HiFonics W124
  • 2
TD.....
TEXAS
I'm currently running 2-JL 12WO - 4ohm...125 Watts.....subs, I'm wanting to upgrade to some HiFonics W 124 * Sensitivity: 90 dB * Frequency Response: 30-100 Hz * RMS Power: 300W * Peak Power Handling: 600W * Impedance: 4 ohms......... With the current amp I have will It make a that much of a difference to upgrade subs.
Or will I be better of getting one more JL 12 WO. My ****ing Amp hammers the JL 12's like nothing...........will getting subs with increased watts hit harder. I have a JL Amp Rated Power: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: 95dB below rated power
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Features: Differential-Balanced Input Topology: (1 pair of inputs) On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire +12V and Ground connections: accept up to 4ga. Wire
Here ya go dude I awsnered you question down a few posts the one you posted a few ago i read it a little wrong but basically do upgrade subs get another and differnt amp like a jlk 500/1 amp and you will notice a huge differnce.
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
294
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
544
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
TD.....
TD.....
TEXAS
jlman
    May 24, 2024
    May 23, 2024
