JL W7 & Sedan Issue
Mp3Supply
Right now my setup is fine the way it is. But this is my problem.
I went from a 02 Celica which is a hatchback to a Sedan 05 GLI. Now i know the sound is different in a sedan vs a hatchback.
Before my w7 hit very very hard in my hatchback and keeping my amps all set the same as they were when I took them out of my old car, I don't seem to be getting nearly as much bass out. My box is built to spec for a 10" w7 based on JL recomendations in a sealed box. My subwoofer faces the rear of the trunk sitting flat on on the floor.
Though this summer i plan to re-do my whole trunk and create somthing different. I'm plannin on dropping the subwoofer in the spare tire having it face directly up in hope to get more bass in the cabin.
Note: My trunk is full dynomatted
So my question is what is the best way to get more bass into the cabin?
Should I create a encloser that will have more cubic space? not alot but more then spec?
What is your experience with subwoofer positioning?
I think i really miss my hatchback
My System consits of :
Front : JL Audo XR 650cxi ran by a JL 300/2
Rear : JL Audio XR 650cxi ran by a JL 300/2
JL 10W7 ran by a JL 500/1
Eclipse CD8454
Any insight would be great?!!?
hatchback> anything.
try doing a blow through style trunk setup with the subs facing forward and sealed off from the trunk.
hmm. for the box i built in my freinds legend i have the sub angled up a little facing the trunk lid, and the armrest for the back seat has nothing in its way from letting air into the car, with about a 10" gap between the back seat and the sub box.
it gets loud enough to hurt in a sealed box.
thats the angle. i never tried facing it stagiht up.. mainly cause the trunk of that thing is so limited.
anyways. hope that helps you.
{but thats also a 13.5}
got any pics of it in daylight?
ok . .. so porting it is going to be my answer .. . sounds reasonable. . . if that fails then i will try to cut out the top part of my rear deck and leave the cover over it so that you wont be able to notice. .. but im gonna go for the ported solution. .. .
now i need to do some research. . . i know my idea is going to be clean and sexy. .. to the drawling boards.
Mp3Supply
Mp3Supply
Pennsylviana
Mr. Opportunist
