JL subs and a Kicker Amp Question......
  • Thread starter Unregistered
  • Live activity
  • Replies 4
  • Views 1K
U
Unregistered
Guest
I currently have 2 JL 10's (10W0) in a sealed box. Im pumping the JL with a kicker zr120, bridged. Im thinking of running the new kicker KX300.2 and bridiging to 1 channel at 300 watts. So if the amp is bridged and the speaker handleing is 125 watts a piece for the JL's (250 watts total) am i over powering the JL's. thanks in advance for your help.
youll be fine running your 10'' jls
with the kx-300.2 if you can
spend a little more get the kx400.2
more power --each sub will be getting
200 watts each compaired to 150 watts
from the kx-300.2 alittle extra power wont
blow your subs.
I also have (2) jl 10w0's in a sealed box (.75cuft each). I have a jbl bp600.1 amp on them putting out 600 watts rms to both combined (300rms each) and have had no problems so far (little over a month). As long as you don't "abuse" the power you will definately be o.k.
Guest
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
