JL New 13TW5
Good luck with it. I hope it works out to your expectations. Keep us posted.
(tl numbers would be sweet too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif)
as soon as everything gets here i will be sure to post pics and im working on getting a better cam for vids
Check out the new re audio SL its 3 inches tall and has 16.5 xmax, looks nice imo
Just went into RE site, its an awsome looking sub, anyone heard it? is it a SQ, SPL or SQL sub? How would it compare to the jl tw5?
How much is it?
How much is it?
You think they designed and built a slim-line SPL sub? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
People are getting way too hung up on these terms anymore. Its like, if someone builds an SPL rig and it doesn't hit the numbers they want, they tell everyone its SQL. Or someone builds a setup with dual 15's on strapped 3000 watt amps and calls it SQ. Silliness. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Wait wait wait....that's not an SQ setup?! //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Its what ever the owner decides to call it. Duh!
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have dual 12's on 1000 watts, is it an SQ setup? Yes, the way I have it adjusted it is, can it also be an SPL setup? Yes, if I turn the sub level up then it is definitely an SPL set up. You can have both in the same setup if you adjust it right.
No, you can't. There is more to an SQ versus SPL setup than where you set your gains. You would, at very least, need to be running an interchangeable port setup before id even consider agreeing that your system is 'both'. Not to down your system in any way, Im sure its nice.
But in the end, we are arguing semantics. I have no link to a definition of an SPL setup. So like I said, in the end its all in what the owner wants to call it. Silly as it may be.
BTW, 1000 watts on two 12's is a far cry from the example I gave.
not my thread but im not going to bother digging mine up.
just an update for anyone wanting to see results or those who expect little from these.
just called my friends shop he said all my stuff should be here friday. everything should be in over the weekend as long as its decent weather.
and yes as soon as its in i will have TL scores with pics to post
True, but it isn't traditional SQ. And yes, you are right, mine is an SQ setup that just so happens to be pretty **** loud. I built the box to Nick's spec's which were geared for SQ.
Updates? I plan on buying one of these to put in my s2000.
zierbox
Only The Very Best
zierbox
texas
Bassin Buick
