Yes, the 15-20mm more excursion is USEABLE. The motor is not completely linear (read below 71% bl) to that point, but it will get the suspension to move that far. Furthermore, it, like the XBL^2 motors has a flatter bl curve that will mean less distortion as it approaches its limits. At which point, it will be loud enough to make most distortion unnoticable due to vibrations and simply volume produced.
Actually, when we talk about thermal powerhandling, 9 times out of 10 we are talking about how much power the coil itself can take for a given amount of time. But, since you want to think otherwise, why do you think that a sub with a larger coil, more excursion capability, both motor and suspension considered here (aka xmech), and a much superior cooling system wouldn't be superior in power handling?
You wanted proof, I assume manufacturer's since there's been harping about it in this thread, so here you go.
http://jlaudio.com/subwoofers/RP_Chart.html
As you can see, the 13W7 actually is warranted up to 2000w. So, there's your evidence.
