JL Audio System
BulldogSr07
What do ya'll think of this setup:
Head Unit- Pioneer DEH-P8600MP
Coaxial speakers- JL Audio TR350CXi
JL Audio TR650CXi
JL Audio TR570CXi
Subwoofer- JL Audio W7 13.5" in a 2.375^ft ported box tuned to 30Hz
Amplifier- HIfonics 1000
I'll take any suggestions on how ot make it sound better.
This is all in a 1992 Mustang GT Hatchback (Hatchbacks rule!!) //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
My opinion: Drop the TR350 and the TR570, upgrade your main front source to at least the XR650CXI. (JL has a new ZR series). Purchase you a nice amp for the front stage and your done.
Up to you, keep the TR570 for rear stage.
It produces well over 1400 RMS @ 4 ohms, a little more @ 3 ohms //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ... Some produce over 1500 @ 4 ohms ...
I know!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I was guesstimating!(sp?)
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
389
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
Look at Recoil components front and coaxials rear. Cheap solution. The Taramps is fine, or Recoil, or blackbrick 100.4 for $69 shipped. More...
BulldogSr07
BulldogSr07
Jennings, LA
limitkid7
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
