Jensen Power Plus 840
Probably not. Jensen has a nasty habit of rating its amps at 2% THD (check the PDF manuals for all the current models). So, most likely their amps don't actually do the rated power at 1% THD. Having said this, I had no problems using the 5-channel Jensen amp (rated for 70watts at 2% THD, but crutchfield lists 60watts at 1%THD). for powering my front speakers.
File this one under “Who Would Have Thunk It?” The fuse to the solar array blew (for some reason). That was causing a dip in power to certain...
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Crutchfield is really good about that sort of thing. Not the cheapest prices but you know where your money went if you ever have any technical...
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
Whytellyou
GA
THATpurpleKUSH
