Jeep YJ, getting loud.
cha0
Whats up CA,
Looking to install a 10'' in my YJ but unfortunately now that im in an apartment I have no place to build a custom box. I was curious what you guys thought about this. I know these pre built boxes **** spec wise but im wondering If I can make this work. This is what im thinking.
Jeep Wrangler CJ YJ TJ Sport 2 Door 10" Black DF Subwoofer Sub Enclosure Box | eBay
This box is nice because it has the cutout for all the trunk latches. So im thinking about modding it. There are 2 separate chambers. I was thinking about cutting out the center of the inside to make one big 2.5 cu Ft chamber. Then from the inside just putting a piece of MDF over one of the 10'' holes, drilling it down and sealing the seams from both sides. Now I have a single 10'' enclosure with a 2.5 cu ft chamber.
Then I was thinking about putting some aero ports on the back side. If I run the aero ports out the back under the back seat I can keep the internal volume probably around 2.3 cu ft after disp. So like 1 3" aero on the opposite side of the driver.
Any thoughts on this? Totally stupid? Would I be better off leaving it the way it is and putting 2 10s in and leaving it sealed?
I think doing the mods above with the single chamber, single 10 and ports is going to get me louder. Im going for mostly SPL since SQ in a jeep is pointless.
Thanks in advance for any ideas guys.
Alright, after some figuring, I think im going for it. patching up one of the openings and cutting out the center divider. Going with 1 AQ HD10 driver, 1 4'' Aero port out the side tuned to 40hz. This should give me 2 cu ft after dis. Ill run all of it off a SAZ1200D for the time being and see how it sounds.
With such limited space I really cant upgrade the driver so in the near future I may go with a little bigger Alt and try and feed the 10 somewhere closer to 2k.
cha0
cha0
Chicompton
cha0
