Jeep grand cherokee sub install help...
Blinkrazy
Secretary of the Internet
how should i go about installing the remote turn on and rca's to the back of a factory hu in the above car? 2002-2004 model, should i just splice the remote on into the "blue" hu on wire, and then where does the rca output go?
-thanks for any help, Jimmy
so you are installing a amp/sub with a factory deck??
you are going to need a L.O.C. (line out converter) hook the LOC up to rear speaker wire's behind the factory deck, and use the Ignition wire for Rem. turn on make sure you fuse the wire.
what does the ignition wire look like specifically, the one from the back ot the key start? thing
no you want to hook everything behind the factory deck.. that way if you ever install an aftermarket deck ur rca's and rem. turn on are right there where you need them. just pull out the LOC and hook rca's and rem to the aftermarket deck..
there is a ignition wire in the factory wire harness behind the deck. test it with a multi meter or test light, should turn on with the key.
fuse ur rem. wire allso. the one you will hook up ignition to off to the amp.
what sould th dmm read, i already have one, so it just shows reading when the car turns on, sry for the noobage, igenerally stick to aftermarket hu's buta friend wants to keep his stock...
Thanks for the help so far though
what sould th dmm read, i already have one, so it just shows reading when the car turns on, sry for the noobage, igenerally stick to aftermarket hu's buta friend wants to keep his stock...Thanks for the help so far though
should show 12v with the key on. and when the car is running. 0v when the car is off.
Blinkrazy
Blinkrazy
Macon, GA
Blinkrazy
