JBL Stadium subs with switchable impedance.....could someone explain how these work?
98 SNAKE EATER
After a bit of debating what sub(s) to add to my Sienna's factory JBL system (see old thread link), I decided to go with a single 12 mounted in a custom glass stealthbox that fits in a rear pocket meant for the 8th seat storage
(work in progress)
The sub I chose is a JBL Stadium 1224 that has a switchable impedance from 2 to 4ohms
Can anyone explain how exactly they're able to do this?
Dual voice coils with a switch. Nothing new and ground breaking, manufacturers have used various methods to achieve a switchable impedance for at least the past decade.
Ok, could you tell me how they're able to achieve either a 2 or 4ohm load?
I've seen other switchable impedance subs that switch from either 2 to 8ohm, which would be simple on a 4ohm DVC sub that uses a switch to go from series to parallel, but this sub has me stumped.
At first I thought perhaps the switch would just cut one of the two coils.
Like if it was a 2ohm DVC wired in series to get 4ohms and the switch would just disable one coil to make it a 2ohm load....
Or if it was a 4ohm DVC wired in parallel to get 2ohms and the switch would just disable one coil to make it a 4ohm load....
But of course, if this was the case, it would cut power handling in half and it wouldn't be nearly as efficient.
Next thought was perhaps a resistor built into the switch, but I can only imagine what kinda heat issues that would cause.
I actually contacted JBL/Harmon directly and none of their reps could give me a straight answer as to how it's done.
It's either 2 or 4 bro, that how dvc's work.
Umm, no
If you have a 4ohm DVC, you get either 2ohm wired in parallel or 8ohm wired in series (like this)
If you have a 2ohm DVC, you get either 1ohm wired in parallel or 4ohm wired in series (like this)
This DVC sub somehow switches from 2ohm to 4ohm
How?
I dunno
It's a resistive switch.
Not doubting you as I'm still rather clueless about this, but the switch on mine doesn't appear to have a resistor bank, just looks like an ordinary switch board with some really dinky lookin wires :unsure:
That being said, I just found this old Sonic video introducing an Infinity Kappa sub with SSI (I believe they share the same switching setup), but they claim to have a triple voice coil in order to switch from 2 to 4ohms 🧐
I actually demo'd both these brands and comparabley priced Morel 3 way set up and would reank them as follows: 1) Morel 2) Focal 3) JBL I also...
True i just found out today, so i think i’ll go with stadium sub with 4ohm mono amp 600w if this even exists i been looking everywhere its like...
10
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
98 SNAKE EATER
98 SNAKE EATER
Jamaica, NYC
98 SNAKE EATER
slater
    May 2, 2024
slater
    May 2, 2024
