JBL Stadium subs with switchable impedance.....could someone explain how these work?
98 SNAKE EATER
After a bit of debating what sub(s) to add to my Sienna's factory JBL system (see old thread link), I decided to go with a single 12 mounted in a custom glass stealthbox that fits in a rear pocket meant for the 8th seat storage
(work in progress)
The sub I chose is a JBL Stadium 1224 that has a switchable impedance from 2 to 4ohms
Can anyone explain how exactly they're able to do this?
Dual voice coils with a switch. Nothing new and ground breaking, manufacturers have used various methods to achieve a switchable impedance for at least the past decade.
Ok, could you tell me how they're able to achieve either a 2 or 4ohm load?
I've seen other switchable impedance subs that switch from either 2 to 8ohm, which would be simple on a 4ohm DVC sub that uses a switch to go from series to parallel, but this sub has me stumped.
At first I thought perhaps the switch would just cut one of the two coils.
Like if it was a 2ohm DVC wired in series to get 4ohms and the switch would just disable one coil to make it a 2ohm load....
Or if it was a 4ohm DVC wired in parallel to get 2ohms and the switch would just disable one coil to make it a 4ohm load....
But of course, if this was the case, it would cut power handling in half and it wouldn't be nearly as efficient.
Next thought was perhaps a resistor built into the switch, but I can only imagine what kinda heat issues that would cause.
I actually contacted JBL/Harmon directly and none of their reps could give me a straight answer as to how it's done.
It's either 2 or 4 bro, that how dvc's work.
Umm, no
If you have a 4ohm DVC, you get either 2ohm wired in parallel or 8ohm wired in series (like this)
If you have a 2ohm DVC, you get either 1ohm wired in parallel or 4ohm wired in series (like this)
This DVC sub somehow switches from 2ohm to 4ohm
How?
I dunno
It's a resistive switch.
Not doubting you as I'm still rather clueless about this, but the switch on mine doesn't appear to have a resistor bank, just looks like an ordinary switch board with some really dinky lookin wires :unsure:
That being said, I just found this old Sonic video introducing an Infinity Kappa sub with SSI (I believe they share the same switching setup), but they claim to have a triple voice coil in order to switch from 2 to 4ohms 🧐
98 SNAKE EATER
98 SNAKE EATER
Jamaica, NYC
98 SNAKE EATER
