JBL P660C Power 6.5" Components
trumpet
Barry Schanz
NIB
2 sets available
How do these compare to MS-62C?
You get a midrange with a larger motor for more thermal dissipation and higher power handling. The cone is a hexagonal laminate type which should have minimal flex when the volume is pushed to ridiculous levels. The tweeter is silk rather than titanium. The tweeter hardware gives the option of dialing in the exact angle to aim them, as the hardware is marked in degrees on the back side. The crossovers only have a 0 dB/-6 dB switch for tweeter attenuation, so you don't get quite as much to play with. They're very substantial in weight and overall appearance, very nice.
This auto loudspeaker features some of JBL’s best technology. Its HCL™ woofer cone is exceptionally stiff, yet lightweight for increased efficiency, exceptional midrange clarity and lower distortion at high-output levels. Its oversized voice coils increase power handling while minimizing distortion. Its spider-integrated tinsel leads enhance reliability and eliminate audible tinsel lead slap. Its Plus One™ (patent pending) woofer cones, with more surface area than competing models of the same size, offer increased bass output and increased efficiency. Its computer-optimized, passive crossover has been voice-matched to ensure optimum imaging, clarity and detail. And its high-bandwidth, edge-driven textile dome tweeters provide reduced distortion at high-output levels.
  • Power handling, RMS 90W
  • Sensitivity (2.83V @ 1m) 94dB
  • Frequency Response 45Hz – 23kHz
  • Impedance 2 ohms
  • Cone Plus One Honeycomb Laminate (HCL) Cone
  • Tweeter High-bandwidth, edge-driven, textile-dome tweeter
  • Crossover Computer-optimized voice-matched outboard passive crossover
  • Tweeter protection (PTC) Yes
  • Tweeter-level control Yes
  • Mounting Depth 2-1/4" (woofer)
$180 shipped, PRICE IS PER SET, NOT BOTH SETS TOGETHER
free UPS Ground shipping to the Continental US
Looking for a component set for a friend. How realistic is that 85W power rating assuming proper HPF?
As with any good component set, they will take rated power all day long with an appropriate high pass filter. Assuming your friend wants to be able to play the music loud, I would go with no lower than an 80 Hz HPF with at least a 12 dB/octave slope. 24 dB/octave would be ideal.
Sounds good. PM me payment info please.
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
    Jun 11, 2026
RobGMN
    Jun 8, 2026
