Ok I've had the system installed for a little while and there was alot of noise and after some re-grounding most of the noises went away there was a faint kind of high pitched noise maybe "airplane noise"? that I just accepted at the time because I had made it so much quieter it seemed like nothing..... Until now
While going through the checklist of ground loop issues I decided to just eliminate both my sub amp and my High/mid amp and go straight from the MS-8 and I still have the noise. So the current setup is Signal from my Factory Amp (front left and right speakers) to the MS-8 and I'm now using the MS-8 internal amp to my front tweeter and mids 4 channels total. Still have the noise. The mic is not connected and i tried to disconnect the display as well to see if it helped and it didn't. I had the remote turn off set to 5 seconds and that noise stays for the 5 seconds after the display turns off until it completely shuts down. I made a new ground just for fun. Maybe I'm missing something? Bad MS-8?
