JBL crossover help...strange issue
  • 2
Maussimo010
Boston
I'm installing a new Alpine head (ILX-W650) unit in a 2016 Ford Transit 150. I'm using a JBL component set (JBL GTO609C) in the front. I got the left side installed and everything was working fine and sounded great. I started to hook up the left side and as soon as I connected the feed wires to the IN on the crossover on the right side of the van, the left side went dead, as in no sound. If I disconnect it, the left side works again. I am pretty sure my connections are all good as I soldered everything and used heat shrink tubing. I used the wire that had a tracer on it as my ground wire for the speakers. If something is reversed polarity on the left side, would it cause the sound to go out on the left when I hook up the right? Or are they independent of each other?
Any help is greatly appreciated!
Turn off the radio, connect the right side, then turn it on. Make sure your crossover is clean of small wires that can short the current.
Solved.
I ran the tweeter wire through the door rubber bellows with the rest of the door wiring and it got pinched and grounded out against the body when I clipped the door harness back in.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
846
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Maussimo010
Maussimo010
Boston
Maussimo010
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
