Sold JBL and Zapco amps
REF350.2
Two Channel
Stereo, 4 ohms: 2x100 Watts
Stereo, 2 ohms: 2x175 Watts
Bridged, 4 ohms: 1x350 Watts
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate: >29V/uS
Damping Factor: >200@4 ohms
Dimensions: 15"L x 7.5"W x 2"H
-SymbiLinkル Balanced Inputs
-RCA Unbalanced Inputs
-2 ohm stereo stable
-18 dB variable bass boost
-Built in variable electronic crossover
-Bridgeable
-Three channel capable
-High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R Sum Mono switch for use as bass amp
-Surface mount technology w/1% resistors,
precision caps, and massive ground planes
JBL 600.2 (birth sheet shows 655 wrms bridged)
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 180W x 2 @ 14.4V
THD at 4-Ohm RMS Power:0.04 %
Bridged RMS Power @ 4 Ohms:580W x 1 @ 14.4V
Speaker Level Inputs:No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: None
Frequency Response: 10-97,000 Hz
Signal to Noise Ratio:79.5 dB
Fuse Rating:n /a
Full MOSFET Power Supply
"Direct Connect" Terminal Block Allows for 4 or 8 Gauge Power Wire
Die-Cast Aluminum Chassis with Top Plexiglas Viewing Window
Variable High-Pass / Low-Pass Crossover (32-320 Hz)
Selectable Crossover Slope (12 / 24 dB)
Dynamic Bass Optimization (DBO) Subsonic Filter
Preamp Outputs
Fully CEA-2006 Compliant Power Ratings
It comes with the transmitter. Everything is included, manuel, transmitter, and birthsheet. (shows 393.3w since birth sheets seem to be important on here)
atsaubrey
SQ is the real deal
atsaubrey
CA
atsaubrey
