JBL amp?
Jeepin
Right now I am thinking of putting 2 RE 8's in the rear of my Wrangler. I am thinking of running the JBL GTO301.1 amp to power them at a 2 ohm load. Would this be sufficent or close to overkill? The subs run at 175 wrms which I'm sure you all know. There is just something to be said about those JBL amps... they are purddy! //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
Here is a link the the specs on the JBL.
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO301.1&ser=GTS&cat=AMP
Too much or too little power?
After I read my first post I got to thinking. Does RE make the RE 8's in a 2 ohm DVC configuration? I can't remember correctly but I thought I read a thread saying they were only making 4 ohm DVC's? //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
So what are my options then if I wanted to use this amp? I can't really justify spending $25 for an option on a sub that only cost $50 to begin with. I want to stick with 2 RE 8's and hopefully this amp. Are the older model 8's 2 ohm DVC's?
Well, let me ask this question. If I were to run this amp at its 4 ohm rating of 204 wrms, what wattage would the subs see? Also, same question for running it at 2 ohms with a load rating of 294 wrms wired either in a parallel or series configuration. I can't remember how it works out... //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
at 4ohms 102w each, which is plenty of power.
DVC 4ohm subs dont do to 2 ohms only 4ohms or 1ohm
Now if you got some DVC 2ohm wired @ 2ohms they would get about 150w each.
Jeepin
Jeepin
Justin, TX.
supa_c
