jbl 1200.1
"running the amp in one ohm will shorten its life". those are the words of a tech at jbl.
im not the smartest, but i would recommend 2 ohms minimum. the higher damping factor will make your bass sound alot better and put less stress on your electrical system.
the thing is i have 2 treo ss1244 which are dual 4ohm so i can either run them in parallel and get 1ohm or series and get 4ohm
what would you sugest i do.
if i sould wire them in series what amp would you sugest i run them on? (im sorta on a budget so it cant be to expensive)
thanks
No__ID
No__ID
bakersfield,CA
Mr. Loki
