Jbl 1200.1
gains are ALWAYS to be watched. They adjust the INPUT VOLTAGE, they are not output indicators. You should use a DMM to set them no matter what the sub is rated at. Clipping and distortion are the result of setting your gains too high. You adjust INPUT voltage to get the correct OUPUT voltage.
don't those amps put out the same wattage from 1-4 ohms?? Or was that the tantrum 1200.1??
then you'd be fine with the subs you have.
Your thinking of the pg xenon that puts out the same power from 1-4 ohms. The jbl can put out full power at 2 or 1 ohms, and the tantrum can put out full power at 2-4 ohms. Its not a good idea to run a tantrum at 1 ohm.
ah yes, the TANTRUM... the gains part was the more important piece of the statement though. So he'd be good with his current subs.
wangchung4541
wangchung4541
Boston, MA
djman37
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
