jbl 1200.1 sound quality ????
Spddracer
Sounds Goooooood
I have had the jbl 1200.1 and the orion hcca 275g4 , I have to say the orion sounds 200% better than the jbl , on the same subs , I have had both on about 3 diff set of subs and the orion sounded better on them all , both amps are rated at 1200 watts the jbl at 2 ohm and the orion at 1 ohm , I have run the orion at 4 ohm which would be putting out 300 watts thats its rating at 4 ohm and the jbl should be putting out 600 watts at 4 ohm wouldnt you think the jbl would be louder and sound better ????? Im not to sure about the jbl , Anyone with any orion / jbl exp please give your opinions ?? Anybody running orion on here ?? Anyone know what the hcca really put out at 1 ohm ?v I know htey are underated and measured at 12 volts , Whats the real power output ??
Well what did you have the JBL frequencies set to? You also must be meticulous about the JBL power, it's a hog for power. Also, look at the price differences, the HCCA is a lot more expensive.
theres no comparison between that orion amp and the jbl. The orion amp is for components and speakers, not subs, and it will be a tad better in sq. The JBL is used mainly for pushing subs, plus its way more efficient than the orion. Plus its about 2-300 dollars cheaper!!!Just my 2 cnets:)
Hey guys here's a similar question. I'm choosing between a JL 300/4 to run focal componets and 1 sub OR run Kappa coaxils off Headunit and use a JBL600.1 to run the sub. I would save 180 on the JBL and 150 on the Kappa's. Would I lose major sound quality or would it be minor? thanx Todd
Spddracer
Sounds Goooooood
Spddracer
Ohio
ridgebikes
