java RTA program? care to have a look?
I played with it a little more and I just need to find more test tones and white/pink noise tracks to see how well it works. I am just unmotivated and lazy right now, I really cant get anything done right now. I will try again later.
That is all
RTA = real-time analyzer.. it analyzes your system and tells you how loud certain frequencies are. then youll know what frequencies need to be turned down to achieve balanced levels of frequencies
yo...if u guys need a quality mic...its easy to connect the karoaki mic to the comp......all u gotta do is go radio shaq...buy a mic and this little adapter for like 5 dollars....
that mic will be HORRIBLY inaccurate.
this mic is relativly cheap and is pretty accurate
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=248-625
an RTA uses a mic to input data in a processor that displays a bar graph of a certain ammount of frequencies, and you can use this graph to see where your system needs 'eq work'.
its over the top for 90% of peoples installs.
ok well ill picc up that behringer emc8000 sometime. btu i need a preamp that will plug into my sound blaster live.. my sound blaster live only has headphone-sized outputs. what pre-amp will suit me? so then all i need is a mic pre-amp and RTA software correct?
i still dont know how a pre-amp is going to plug into my soundcard if my soundcard only has headphone-sized outputs. i dont even see any pre-amps that use headphone-sized outputs... isnt that what im looking for if i already have a mic and a soundcard??
req
am a mod.
req
Syracuse, NY
noob with an RS
michigan born
    May 14, 2026
michigan born
    May 14, 2026
