ßûmþ_§üm±hîñ 10+ year member
hey guys, ive got my choices narrowed down to seven different subs. please just read the stuff and tell me what you think would be the best quality for cash decision. thanks...
1. Rockford Fosgate HX2 RFD2212 12" DVC SUB (only 1 sub)
**$129.00
Rockford Fosgate Punch HX2
12" Dual Voice Coil Subwoofer
New model for 2001
BRAND NEW IN ORIGINAL CARTON!
One low-frequency roar from the RFD2212 and those inferior subwoofers will be scrambling for cover. This Punch HX 12" subwoofer is built with the famous Rockford Fosgate attitude - a no-compromises commitment to deep, powerful, and realistic bass.
The FIBERlock cone of treated cured paper is strong and light for high performance and excellent transient response. Those bass notes go down smooth, too, thanks to a durable Santoprene rubber surround that controls the cone's path for maximum excursion.
The cast aluminum frame basket reduces flex and resonance for greater accuracy, while aluminum formers allow the voice coils to dissipate heat quickly. The dual 4-ohm voice coils can be wired as a 2-, 4-, or 8-ohm load, giving you more options when hooking up your system. 1-year warranty.
Features:
CONsealer gasket hides mounting screws and prevents air leaks around the frame
frequency response 26-200 Hz
power range 150-500 watts RMS (250 watts per voice coil)
peak power 1,000 watts
sensitivity 88 dB SPL
top mount depth 5-13/16"
sealed box volume 0.8-4.0 cubic feet
ported box volume 1.75-4.0 cubic feet
2. PAIR CERWIN VEGA 12 HED SVC SUBS 800W
**$127.00
CERWIN-VEGA
HED-12 SVC
12 COMPONENT SUBWOOFER
PAIR OF SUBS! 2 PC'S
BRAND NEW IN FACTORY SEALED CARTON
The woofer cone is constructed of injection-molded pearl-mica polypropylene coated with a titanium-nickel alloy. Uniform pearl-mica crystals form an overlapping structure that adds strength and heat resistance to polypropylene, resulting in reduced distortion and improved reliability. In addition, the titanium-nickel alloy coating adds even more strength, giving you deep powerful bass.
VEGA-flex Suspension
The V-Flex surround mechanically resists lateral "cone drift" for perfect pistonic movement of the cone, a distinct advantage particularly in high power handling. Outstanding linearity under hard drive/high power applications; long throw with minimum lateral cone "drift"; resists ultraviolet radiation. High power handling with low distortion; extended low bass output.
High Energy Strontium Ferrite Magnet and Handwound Voice Coil
The 112-ounce motor assembly and 2" precision hand-wound voice coil provide high efficiency and greater control for fast transient response and sonic accuracy.
Titanium Nickel Alloy Vapor-deposition Polypropylene Injection-molded Pearl-mica Cone
Uniform cone thickness; proprietary ribbing pattern for rigidity. Deep powerful bass and smooth response; detailed percussive attack; low distortion under extreme loading conditions.
High Temperature Kapton Voice Coil Former
Increased magnetic efficiency; excellent heat dissipation for high thermal power handling.
KEY FEATURES
Titanium-nickel plated polypropylene cone
Power range 200 watts RMS each 400 watts total RMS
Peak power 400 watts each 800 watts max
Frequency range 20-500 Hz
Single Voice Coil
Sensitivity 90 dB
Top mount depth 5-1/4"S
Sealed box volume 1.1 cubic feet
The HED is a new generation of subwoofers featuring landmark technology and outstanding performance. The HED subs sport a unique surround and Cerwin-Vega's proprietary V-Flex suspension design.
3. PAIR AUDIOBAHN AW-1251X SUBS 1400W
**$99.00
AUDIOBAHN WOOFERS
AW-1251X
(2) 12 1400 WATTS (TOTAL)
NATURAL SOUND SUBWOOFERS
BRAND NEW IN FACTORY SEALED CARTONS!
PAIR OF WOOFERS!
FEATURES :
12 NATURAL SOUND SUBWOOFER
MACHINE CHROME BACK PLATE
NICKEL PLATED LUG-LOCK TERMINALS
EXTENDED & VENTED POLE PIECE
400 WATTS R.M.S., 700 WATTS MAX. POWER HANDLING EACH SUBWOOFER
45 OZ. STRONTIUM MAGNET
PHAT FOAM SURROUND
NON- PRESSED, NON-TRANSSFER PAPER CONE
KM3 COATED FOR VIRTUALLY NO CONE DISTORTION
2 4-LAYER ASV VOICE COIL
DUAL 4 OHM
2 OHM OR 8 OHM OPERATION
FREQUENCY RESPONSE 24Hz TO 1 KHz
EFFICIENCY 92.1 dB
4. 2001 AUDIOBAHN AW1000 10" 600 WATT
**$78.00
New model for 2001
AUDIOBAHN AW1000
10" HIGH EXCURSION WOOFER
Power Handling: 600 watts R.M.S.
New model for 2001
AUDIOBAHN AW1000
High output bass is all about high excursion - if you want maximum SPL, you've gotta move some serious air. That's why Audiobahn's AW series subwoofers have Phat 2" foam surrounds and non-pressed, non-transfer paper cones coated with KM3 for huge amounts of excursion. To handle the rigors of tremendous linear movement, the baskets are made from ultra-stiff chrome plated cast aluminum, and even the back plate is machined and chromed. Designed for super high output, the AW1000 features huge 120 oz. double-stacked Strontium magnets, a vented and extended pole piece, and a 2" ASV former with dual 4-layer high-temp 4 ohm voice coils. All this beauty and brawn comes packaged in a heavy-duty wooden gift crate
SPECIFICATIONS
120 oz. Double Stacked Strontium Magnets
Frequency Response: 23Hz - 500Hz
Efficiency: 91.1 dB
PHAT 2 Inch Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3 Coated for Virtually No Cone Distortion
2.5 Inch 4-Layer ASV Voice Coil
Dual 4 Ohm 2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 5 Inch Hole; 9 1/4 Inch Diameter; 10 7/8 Inch
5. KENWOOD TORNADO CONE 12" WOOFER PAIR
**$129.95
KENWOOD
KFC-W3003 12" 600 WATTS EACH WOOFER! (PAIR!)
KENWOOD KFC-W3003
600W 12" SUBWOOFER PAIR!
BRAND NEW MODEL!
Features:
42.3 oz Magnet
600 Watts Max Power
Frequency Response - 25 Hz - 800 Hz
Sensitivity 93 dB / Wat 1m
Impedance 4 Ohms
Weight - 9.1 Pounds
These Ones Rock!
YOU GET 2 WOOFERS Brand New In The Box! (Factory Sealed!)
6. KICKER C12 COMP12 SUBWOOFER PAIR
**$109.00
KICKER
C12 COMPETITION
12" SUBWOOFER PAIR NEW IN BOX!
Kicker C12 Competition
Sub Woofer
Description:
The legendary KICKER Comp - pound for pound, dollar for dollar, there's no other sub like it on the planet. It's the sub that made KICKER famous and a universal standard when it comes to making bass. All the innovative design and performance you expect from a KICKER sub are built into every Comp.
Like the XPL and CompVR, the KICKER Comp kicks that famous KICKER bass sound from a sealed cabinet much smaller than most. And now the new Comp gives you even more installation options with great bass performance in ported enclosures and even freeair, with no enclosure at all. It's the most flexible subwoofer KICKER has ever created. Updated for the 21st Century, the 2001 KICKER Comp has a rigid cone with our trademark Inverted Structural Dome for superior flex resistance, increased throw to move even more air, and enhanced thermal dissipation (thanks to Perimeter Venting built into the trick new basket) for cooler operation and longer life.
Comp 4-Ohm Subwoofer Parameters
Model C12-4 C10-4
Nominal Impedance 4 4
SPL dB 1W/1M 88.6 87.7
Displacement, cc 1718 983
Displacement, CuIn 104.89 59.96
Hole cutout, in dia 10 7/8 9 5/32
Mounting Depth, in 5 1/2 4 9/16
Revc 3.79 3.645
VC Inductance, mH 2.83 2.7
Sd, SqM 0.0532 0.037
BL 11.69 10.17
Vas, Liters 133.27 59.48
Vas, CuFt 4.71 2.1
Mms, gms 107.3742 75.8088
Fs 25.8 32.2
Qms 11.298 10.534
Qes 0.499 0.555
Qts 0.478 0.527
Pmax, watts 300 250
Xmax, mm 7.5 7.5
This is a Brand New,Kicker 4 Ohm 12" Competition Sub Pair , which has never been used. It is not refurbished This pair retails in store for $300+, now is your chance to own it for much less!
7. INSANE 12" WOOFERS! 2400 WATTS TOTAL (FireStorm)
**$89.00
FIRESTORM PRO SERIES
1200 WATTS EACH
12" SUBWOOFERS!
YOU GET A PAIR! (2 PC'S)
HIGH FIDELITY PROFESSIONAL SERIES SUBWOOFER
NICKEL COATED DIE-CAST BASKET AND END PLATES
STRONTIUM CARBONATE FERRITE MEGA 200oz MAGNET
HIGHT TEMPERATURE COPPER WITE VOICE COIL
DOUBLE WALLED KAPTON FORMER
SUPER STRONG GAUSS VENTED MAGNET STRUCTURE
HEAVY DUTY POLY COTTON FLAT SPIDER
HIGH-STRENGTH ORGANIC FIBER CONE
HEAVY DUTY RUBBER SURROUND
EXTENDED VENTED POLE PIECE FOR MAXIMUM EXCURSION AND HEAT DISSIPATION
SPECIAL GOLD PLATED TERMINAL
1200 WATTS OF POWER! (EACH WOOFER!) 2400 WATTS FOR THE PAIR!
THESE ARE INSANE! THE PICTURE DOES NOT DO THEM JUSTICE! YOU NEED TO HOLD THESE IN YOUR HAND TO BELIEVE THE INCREDIBLE MAGNET SIZE AND POWER OF THESE SUBS!
YOU GET A PAIR OF THESE, BRAND NEW IN THE SEALED CARTON.
*****OK******
Im sorry that it is soo long but i just need some "professional" help because i dont know much about this whole thing yet...i decided to post all of the information on each set because it might help you compare better...I really need you guys' help and this is the last time i will bug you so please just tell me what you think...later guys, Nick
**$129.00
New model for 2001
Features:
**$127.00
CERWIN-VEGA
HED-12 SVC
KEY FEATURES
Single Voice Coil
Sensitivity 90 dB
**$99.00
AUDIOBAHN WOOFERS
AW-1251X
PAIR OF WOOFERS!
FEATURES :
PHAT FOAM SURROUND
DUAL 4 OHM
EFFICIENCY 92.1 dB
**$78.00
New model for 2001
AUDIOBAHN AW1000
New model for 2001
AUDIOBAHN AW1000
SPECIFICATIONS
Efficiency: 91.1 dB
**$129.95
KENWOOD
KENWOOD KFC-W3003
BRAND NEW MODEL!
Features:
42.3 oz Magnet
600 Watts Max Power
Impedance 4 Ohms
Weight - 9.1 Pounds
These Ones Rock!
**$109.00
KICKER
C12 COMPETITION
Sub Woofer
Description:
Model C12-4 C10-4
Revc 3.79 3.645
BL 11.69 10.17
Vas, CuFt 4.71 2.1
Fs 25.8 32.2
Qms 11.298 10.534
Qes 0.499 0.555
Qts 0.478 0.527
Pmax, watts 300 250
Xmax, mm 7.5 7.5
**$89.00
1200 WATTS EACH
12" SUBWOOFERS!
*****OK******
