desertheat
Many of you know I am one of the local DLS *****s on here that LOVE DLS amps. I had a sexy A7 in my show car all of last year when I got this itch to change out to somthing new for 07. I had the goofy idea of going with helix series amps for 07... well that idea lasted for a little bit. Then found myself staring at more sexy DLS ultimate amps online. Called DLS, planned and crunched numbers...
Well I decided to go with my dream active setup! I just ordered in 2 DLS A3 twin mono amps along with 1 A6 mono sub amp. The first a3 will power the top end while the second the front mids. The big mono powering the bottom. I know this is insane overkill power wise but what the hell, why not! Here are some of the specs... Man finally! I will have the amp setup I have dreamed about! This should be perfect coupled to the insane functions of the Ural CDD.....
TWIN MONO A3 AMPS....
http://www.dls.se/images/highres/A3_F.jpg
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode : AB
Number of channels : 2
Output power in 4 ohm : 2 x 150 watt
Output power in 2 ohm : 2 x 270 Watt
Output power in 1 ohm : 2 x 425 Watt
Output power in 4 ohm bridge mode : 550 Watt
Output power in 2 ohm bridge mode : 870 Watt
Output power in 1 ohm bridge mode : 1200 watt
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight : 6,2 kg ( 13,67 lb)
A6 MONO
http://www.dls.se/images/highres/A6_F.jpg
Mode : AB
Number of channels : 1 ( for subwoofer use )
Output power in 4 ohm : 500 W
Output power in 2 ohm : 870 W
Output power in 1 ohm : 1200 W
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control with phase shift : Yes
Current draw, idle : 0,6 A
Mode : AB
A6 MONO
Mode : AB
