Issues installing stereo system in cooler ... please help
Hi there! Newbie here ... I need some help with my set up: two amps, two speakers, two subs and 12 volt battery. This is what I have:
https://www.crutchfield.com/p_206PXIB502/Kicker-40PXIBT50-2.html
https://www.crutchfield.com/S-DDbh5mfhPwJ/p_206PX2K1/Kicker-12PX200-1.html
https://www.crutchfield.com/S-7IN9OonAoD8/p_1131653MRB/Kenwood-KFC-1653MRB-Black.html
https://www.crutchfield.com/p_206CWRT672/Kicker-CompRT-43CWRT672.html?avf=N
https://www.crutchfield.com/p_007CK10/Crutchfield-CK10.html
I connected the main amp (used 10-amp fuse) and sub amp (15-amp fuse) to a 30-amp-fuse distribution block and then to battery. I used manufacturer wires from amp to terminal block. From terminal block to 30-amp-fuse distribution block I used 10-gauge wire for power and ground that came with the amp kit mentioned above. Finally, I used same 10-gauge wire from distribution block to 12v battery for both power and ground.
I checked all my wires before turning on my setup, recharged battery, etc. When turning on, the amp comes on for a second and goes off. I disconnected everything and only wired main amp with same setup mentioned above and still nothing. What am I doing wrong? Please any help will be appreciated.
Thank you!
Hi there! Newbie here ... I need some help with my set up: two amps, two speakers, two subs and 12 volt battery. This is what I have:https://www.crutchfield.com/p_206PXIB502/Kicker-40PXIBT50-2.html
Thank you!
What vehicle is this in ?
I would probably start by watching what the voltage does when you turn the system on. Measure it right at the amp inputs. If you see a significant voltage drop, run the same test at the battery. If the battery voltage stays solid then you have a problem with your power or ground wiring. Also double check voltage on remote turn on.
Since everything is so close together you could also just measure resistance of battery and ground cables from the battery to the amps. Should be less the 0.5 ohms, probably much less than that since the runs are so short.
I'll check that today. I'll keep you guys posted. Thanks for the tip btw
Sent from my Pixel using Tapatalk
Hey guys ... No voltage drop at all! 13.07v when resting and when powering on amp. Amp blue light turned on and then went off again. I'm attaching some pics (Sorry for the darkness) Also, the blue remote wire will be connected to the sub amp. I only set up one amp to test the power and ground connections. Pic #1 ground wire from amp is copper and ground wire from kit is aluminum (problem?)... Pic #2 power wire from amp and amp kit are both copper.
Again this is the simplest set up and still nothing.
Thanks a lot for your help.
I would start with the main amp first ..Where is the red acc wire connected? The
Dannyelloko20
Dannyelloko20
Farmingville,NY
smichael85
vegang
vegang
