love car audio
I have a problem that nobody can figure out for some reason. Let me be clear that I know a little bit about Car audio but not enough to troubleshoot big issues.
For starters I have a 2005 Touareg with the factory battery underneath the seat in a Kinetik 2400 in the back of the truck.
Avic z-120 head unit
Jl audio 450/4 mids amp
Sound stream amp on sub
Pvr 6s in front door
Kicker qs mids in rear door but they have died (not sure if this is causing the amp to clip or cut out)
So in the morning I go to vehicle start the car up turn the radio on and everything plays fine for about 30 to 40 minutes depending on how hard I'm pushing it. At that point either the sub amp or the mid amp Will start to go into the mode on the JL. Both the sound stream and the JL will eventually start to go in and out. At that point I will turn the volume all the way down and then the sub woofer off from the radio and the radio off after that.
After a minute or two I can hear a clicking noise coming from the tweeter in the front and then a pop from the sub woofer in the back it alternates back-and-forth for about 10 to 15 minutes.
After that 15 minutes the clicking in the front and the supple for pop in the rear stop.
Prior to this I had all kicker mids and highs and H AL 1000 as my sub amp the 450 was the mid amp. I had a smaller kinetik battery and that was it everything else works fine for two years.
The voltage reading to rear battery is 13.9 but at amps 12.
Not sure if it's ground or what.
Open to ideas... More detail the better as I said I am ignorant when it comes to this type of thing and advanced troubleshooting.
