Is this too much power?
200RMS to 800 peak is a wide gap.
All you do is lower the gain on your amp so it doesn't push out around more than ~ 200 RMS to your sub. Set your HU to 80% volume playing common music you listen to and up the gain to a point where your sub doesn't distort. Then play with your bass adjustment and lowering the gain if necessary to reach the level of bass you like *without* distorting the sub. Listen for distortion in your trunk - not from your front seat. It may sound fine up front but in the back you're actually over pushing the limit of your sub.
If your sub can't reach a level of bass you enjoy while not distorting, then you need to look at upgrading the sub.
So, it CAN be done safely, right?
Or should i just buy an amp that puts out 200 W RMS just to be safe?
So, it CAN be done safely, right?Or should i just buy an amp that puts out 200 W RMS just to be safe?
Yes. Like I said - listen for the distortion in your trunk and not from your front seat. Then you'll know you aren't overpowering the sub.
thanks for all of the replies, you have been very helpful. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Jazz
Jazz
Jazz
Montreal
tcguy85
