Is this Setup to much?
aceorama1
I am looking to install Alpine Type R subs into a BMW 1 series. It is a small sport coupe and I have been leaning towards the idea of running dual 4ohm Alpine Type R's at 1ohm at about 700 watts each. I need to know if this is going to be "to much" for the car I'm driving.... would it be better to maybe just have a single Type R?... In other words I don't want to damage anything.
you probably won't be able to fit the box for 2 type R's in that car. better to do a single 12 in a nice big enclosure than stuff 2 into a tiny box.
I agree.
A single Dual 2 would be good for a single subwoofer application, then you have two common choices for impedence, 1 or 4 ohm.
I have put two 15's in sealed boxes before into a tiny trunk, and it sucked. I wanted to go ported, but space is limited in my ride.
A single D2 15" might be a good option too, if you have room to port it.
i could fit a box. I alrdy measured and i can do a box probably just over 4.o cubic feet
huh. i stand corrected. if you could fit 2 cubes per sub, then it would work fine. total box volume with port and sub displacement will be larger than that though.. 2 cubes is just internal volume not counting port and sub. or thickness of the wood.
I agree.
gotta be careful there too. a kicker L7 15 likes 6 cubes. a focal 16 does well in under 3 cubes. it varies.
well assuming i could do something like 4.5 cubic feet would 2 12's be overkill? i honestly dont want to ****up my car
it won't damage it too much. most people wouldn't be listening to 2 type r 12's at full tilt anyway in the right box very often. but, most people haven't heard them in a good 4 cubes tuned to 35hz. almost any 12 is impressive to someone who's only had prefab boxes. it's subjective. no way to tell if it'll be too much for you.
aceorama1
aceorama1
chicago
MBrock4u
