Is this good wire???
The Soundquest isnt flexible at all. Its a pain in the *** to work with, especially when youre wiring 18 batteries with it. Its not bad for running under the car, but If I could afford to run all new wire, I definately would.
Maybe eventually Ill get all new wire. Add about 8 more runs of 1/0ga to the back (only 2 runs of Soundquest now), and run all new speaker wire. Right now I got some tiny speaker wire thats turning black on the tips from being too small, but its what I had, so thats what went in. I want to run 8ga from the amp into the boxm then split off that to 10ga or 12ga into the subs.
Going to be a weeks long project when I do though. But... If I did it, I should see a big gain.
Yeah, wire is wire to an extent. This is one of those items people just skimp on. I wouldn't personally use the sound quest nor the knu. I would suggest the Stinger HPM series or the Kicker kit someone else posted.
You spend $ on components, share some of that $ on wire:)
Top is audiopipe wire = to or better than soundquest middle is knu klmx
and bottom is knu kolossus flex
get knu trust me:D
my digi sucks but................... you get the idea
if the smaller one is copper and others are that CCA stuff I would go with the copper. If you use pure copper it is thinner and thus easier to work with. Plus lower resistance. Judge wire just by thickness and not comparing materials is retarded, o wait ca.com carry on
nchilds21
nchilds21
Falls Church, VA
nickolas_j_t
