puttig 1/0 into terminal
anyone have a secret to putting the 1/0 wire into copper ring terminals? i cant get more than 3/4 of the wire into the terminal without alot sticking out. i have KLMX wire
make sure their 1/0g ring terminals first //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
they are, i bought them from a member that sells them in bulk
what kind are they? are they the ones that have a crack in the middle where you usualy crimp it over? sometimes you can pry that open more and twist the wire into it, its what i do
its a solid terminal with no crack, i might cut it a little to help the cable
yeah i usualy get those ones that have the crack in em, i think their easier for some reason.. just bend one side in, squeeze the other one on top.. and solid connection
ok i got it, i tried to cut the terminal to make the crack thingy, but then i realized that the copper is kind of bendable. so i bent the outer rim of the terminal and squeezed the wire into it, then i hammered that b down and soldered it. PITA
//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
joker4096
F'n Loud
joker4096
Pensacola, FL
quins90lac
