Is this box ok for an SRx?
way2sl0
22 W
17 H
10 D
=1.563 cubes ( Sealed )
All in inches. 15" SRx off of 600w Mrp-m650
Is it a myth or true that slanted boxes make a big difference in cancellation? Or is that just perfect cube shapes?
Thanks for the input guys
btw weight for me makes a difference, will 1/2" MDF be ok? or is 3/4" the ONLY way to go.
A slanted box would help eliminate cancellation. However, unless you box is a perfect cube you shouldn't need to worry about cancellation. Even if you box is a cube cancellation is not going to be very likely to occur.
I personally wouldn't use anything less then 3/4". If you are looking for lightweight then consider doing fiberglass. You could also make the enclosure out of 1/4" or 1/2" and then fiberglass the inside. That would be a lighter way and would still be strong.
Okay, ill use 3/4 MDF. Also for 1.5cu ft I should use 1.5lb polyfill also right?
well fiberglass isnt strong at all on flat pieces, only in corners and around curves
another option is to go with a sandeply or birch, both are light as shit and rigid as hell.
way2sl0
way2sl0
Ontario, Canada
iamamp3pimp
