is this box calc accurate?
Red is the speaker baffle. Black is the back. Teal/violet are the inner walls of the port. Yellow and green are the sides of the box.
Can I use the top of the box as the speaker baffle? Would it effect the sound? Sorry for my ignorance i'm a total noobie.
It would be better to keep the ports and the woofer facing the same direction. Just lie to the program when you give it the width and height.
What do mean by lying to the program? I have 30 inches for the width and 18 inches for the height for the box i'm gonna build. Well i read on the forums that it would be better to have the port facing the rear of the cabin, and have the sub facing upwards to the window in a hatchback.
I thought about adding a "port position" selector box.
Options would be "side", "bottom" and "CRX".
Side is "standard" while "bottom" and "CRX" would have to work around the woofer basket. Difficult since the ports are enormous with those designs.
9:1 ratio with a 40" wide box would yield a 38.5x4.25" port, or nearly 164 square inches. Not really a problem with high-excursion woofers, since the port is going to be that big anyways, but many people wouldn't want that for two or three "entry level" woofers.
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif You are the man.
You're thinking about it backwards.
Since the outer wall of the box is the outer wall of the port, it tends to lengthen the port beyond the inner port wall. To correct, you remove half a port width from the inner port.
http://www.jlaudio.com/tutorials/ports/index.html
One has to remove that length from the inner port wall.
Ok Beerman, I guess I'm still not understanding you here. I went to JL's site and it states "Calculating end factor may sound like it would be more trouble than it's worth, but it's actually quite simple. To calculate end correction factor, simply add one-half of h to the physical length you calculated above (L1 + L2)." Just above this statement it gives a pretty little picture to try to explain. Please help me understand why they say add and you say subtract?
Simple: the JL tutorial helps you determine the tuning of a box that's already built. Note the formula is "solved" for "Fb" and not "Lv". "Lv" is one of the factors that determines "Fb". Determining the "real Lv" in this case requires you to add to the "physical Lv".
Designing a box from scratch requires one to solve for "Lv" (given "Vb" and "Fb") , and then remove the ECF from the "real Lv" to determine "physical Lv".
A word of advice: real gangsta azz fritters don't flex nutz, cuz real gangsta azz fritters know they got em. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
BWUAHAHAHAHA!!
I really appreciate you helping me understand this because this was the only thing that my spreadsheet had gotten wrong so far.
60ndown
60ndown
ca
Goldtaz1
BP1Fanatic
BP1Fanatic
