is this box calc accurate?
If you measure down the center of the port, you'd find that the port length is, in fact, 17.5" ...
0.75" (wall thickness) + 13.5" (teal) + 0.875" (1/2 port width) + 0.875" (1/2 port width) + 0.75" (wall thickness) + 0.75" (violet) = 17.5"
There shouldn't be a violet board at all for 16.75" ...
ACCK!
Include "end correction factor" (subtract port width from overall length since one wall is actually a box wall) and it's all kinds of wrong.
Fark. I have a bit of work to do tonight.
ACCK!
don't u subtract half the port width??? Wish i knew more about this shit.
yea beerman , nice of you to take the time to put the calc up, even if its a little off sometimes-.. its gonna help a ton of people build good boxes rather than real shitty ones. if you keep makeing it better its gonna put alot of box builders out a buisiness? good for us- bad form them. dont be supprised if someone hacks the calc?
Anyone could just look at the source code and either copy or reverse engineer the calculator (not very difficult). Of course, you should at least ask for permission to copy or make modifications to anyone else's work. That's just common decency ...
And, no, I don't think it'll put a lot of enclosure designers out of work ... Not that a lot of enclosure designers should get work either because they don't know WTF they're doing ... Part of having someone else design an enclosure for you is having their experience, knowledge, and expertise in deciding what enclosure is best for you and your application ... This calculator can't do that ...
Good job on the calc, Beerman, I can't seem to find any mistakes yet ... I'll let you know if I find any, though ...
i tried an online box calc guy recently, calced-box and cut sheet were different? tuneing was effected by difference in desighn/cutsheet-box sounded like shit! and he is supposed to be good-he did send me my $10 back tho!
im not gonna say who it was, that just wouldnt be nice
I can't please everyone. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It was designed to make the smallest possible box for a typical daily driver system, given MFR recommendations.
The calculator does hiccup, and I am working on v2.0 to fix the hiccups, among other things.
It will take about 30 seconds to add a checkbox for high SPL, increasing the port area by 33% by changing the minumum port area from 10 square inches per cubic foot to 15 square inches per cubic foot. Would this work, or should I make it even larger?
Ideally, I would take into account woofer parameters and port dimensions to calculate peak port velocity and give the user recommendations if the port is too small or tuning is too low.
Ideally, I would also have all the time in the world. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It better be right be, I used it awhile ago to design my box //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. I was quite happy with the box btw. I actually used v2, found out about the calculator on a different forum you were posting on. Very thoughtful of ya too take your time and do this. Just wanted to say thanks. //content.invisioncic.com/y282845/emoticons/patriotic.gif.b47a6e0394a3738334c387bdf79409f4.gif//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
60ndown
60ndown
ca
Goldtaz1
BP1Fanatic
BP1Fanatic
