Is this amp/speaker setup good?
Sorry lol but ya if you have a decent amp you going to want a decent deck to. But then again you may be happy with the one you have now. What do ya got?
The deck in that car is fine - changing it would be your personal preference.
Based on your speaker choices, it does not look like you are an audiofile you are just looking for a good clean sound and that factory deck would do just fine.
You should be able to add subs to a factory deck, just need an adapter if I'm not mistaken.
BUT IMHO it's wayyyy easier to go aftermarket to add subs. Rather than modifying the factory wiring (if needed) for the factory deck to run subs. Just make sure you have the factory wiring adapter for your vehicle. Like ~8$ from any local car audio shop for the adapter unless you ordered from crutchfield. They'll give you installation tools free depending on what you need.
Nah dont have to replace it to add a sub and amp
But yes like said above its easier and recommended Iam sure to just get a aftermarket HU
if I didn't have to replace the head unit that would be amazing. I wouldn't have to get the big kit thing and there is a $100 harness wire thing I have to buy. if I don't replace the head unit I won't have to buy all those extra pieces I can just hook the speakers straight up to the receiver?
Check the rockford fosgate 360s, JL cleansweep and Audiocontrol line drivers. Much better then a cheap LOC and will not cut off low freq when the volume goes up like the deck will do through a normal cheap LOC
I've decided to switch to a kicker zx350.4 amp. I guess I just need to figure out whether or not I'm going to replace the hu. if I could just replace the speakers and add an amp it would be so much cheaper but I guess it wouldn't sound as good =\
369
337
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
BriIIance
BriIIance
Las Vegas
Papermaker85
    May 18, 2024
    May 18, 2024
