I was thinking about getting 2 12" K series, but i don't know what amp i should use. Audiobahn A8001D? If i used this, how would i wire them so that i get a one ohm load? Thanks in advance.
to get an amp down to 1 ohm lod.. you either need 2 - 4 ohm dual voic coil subs or 2 - 2 ohm single voice coil subs.. the 4ohm DVC's - parallel each sub, them parallel both to the amp. . . the 2 ohm - parallel the 2 coils to the amp ... both will give a 1 ohm amp load.. but make sure the sub will hold that much power and them amp is 1 ohm stable
