Is this a good setup? Alpine + Sony + MTX
I saw yesterday that Ikesound is offering RE SE 12's for $99 each. If that's legit, a pair of those would make a great budget system. I have heard some complaints about ikesound though. *shrug*
Ya I don't mind paying a little more per sub as long as it will suit the amp and is reputable. Just want the best bang for the buck and I'll go up to about $150 per sub at most. Thanks for the info though //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If they really are $99 each, the RE SE's are an extremely good value. Another notoriously good bang for your buck sub in that budget range is the Type R.
why do you need 10s? I think I speak for everyone as for you should return the box as well and have a custom box built because 99% of prefabs are garbage...your best bet is to return the amp, subs, and box then buy one or two SE's, find an amp on here, and if you can build a box yourself or have someone build one for you. I promise you will be way more happy you did.
True I might be happier with a custom box. We'll see. I can always build one later. The box is made with MDF 5/8 (yes it's not 3/4) and it's glued/stapled. I can always run additional supports and screws too if need be. And knowing my woodworking skills, I'd rather buy the box haha.
Anyway the reason I want 10's is that my car trunk is very small. The box I mentioned "just" fits. Some people seem to prefer 10's of 12's I noticed on this site and others. Either way I pretty much want to go with 10's so looking for decent ones that'll run good with my amp. So any suggestions please let me know. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Alpine=Ok/goodSony & MTX=bad
I noticed no one here likes the amp //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif. I know it's not high-end, but what's wrong with it? I figured it would get the job done with some 10's.
From what I've heard, they have a tendency to break.
ahh I see. Well hopefully that happens before the warranty runs out. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
As for specs though, does it seem ok from that perspective?
well then go with two type r 10s and def have a ported enclosure built for them either now or later when you can. may I ask how much you payed for the amp?
Don't ask.... haha. Close to $300 inc s/h and taxes.
Is this a good setup and will I be able to connect these subs to the amp bridged running at 2 ohm's? I've already purchased these items and hope to receive them in the next week or so. The system is going in a mid sized 4 door car. Hope I didn't screw up! Speakers will run off deck amp I guess. They are stock crap anyways. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Appreciate any feedback if possible. The reason I am asking is if there's something I should definitely "NOT" get, I can return the product if need be after it arrives.
Specs...
  • Sony Xplod TR2022 GTR Series 2/1 Channel Amplifier
    http://www.xplodsony.com/xplod/amplifiers/XM-GTR2022
    Class A/B
    600W x 2 Max Power Output
    202W x 2 into 4 ohms, 20Hz-20kHz, 1.0% THD
    Variable 50-300Hz Lo-Pass Filter
    -12dB/oct Selectable Slope
    250W x 2 into 2 ohms, 20Hz-20kHz, 1.0% THD
    Max Power (Watts): 1200
    Ad Hoc Power into 4 ohms, THD%: 202
    Ad Hoc Power into 2 ohms, THD%: 250
    Bridged into 4 ohms, THD%: 500
    Signal to noise ratio (dB): 93dBA
    Frequency Response (Hz): 5-50kHz
    Current Drain at rated output (A): 48A
    Width (inch): 15.8
    Height (inch): 2.2
    Depth (inch): 10.8
    Weight (Approximate): 11.4
  • MTX 10" Car Subwoofer (TC510) x 2
    http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10085244&catid=
    Mfr. Part Number: TC510
    Band Pass Volume Not Applicable
    Basket Material Stamped Steel
    Binding Posts Chrome Push Terminals
    Cone Material Expanded Poly
    Frequency Response 36-150 Hz
    Impedance 4 Ohms
    Magnet Weight 60 oz
    Mounting Depth 6 3/16"
    Ported Box Volume 1.45 ft/3
    Power Handling Max 900W
    Power Handling Nominal 300 Watts
    Product Warranty 1 Year Parts & Labour
    Recommended For Band Pass Not Applicable
    Recommended For Ported Yes
    Recommended For Sealed Yes
    Sealed Box Volume 0.75 ft/3
    Sensitivity Not Applicable
    Surround Material Rubber
    Voice Coil Size 1.75"
    Woofer Size 10"
  • Alpine iDA-X200 Head Unit
    http://www.alpine-usa.com/US-en/products/product.php?model=iDA-X200&lang=en&tab=F
    To much to list. Please see URL.
  • Other
    Bassworx 10" Dual Hatchback Sealed Subwoofer Box (SW210B)
    4 ga. Power Wire
    4 ga. Ground Wire
    18 ga. Turn-On Wire
    1 x 80 Amp Fuse
    Voltage Stabilizer
    etc...
How much was all of that?
o snap //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif please return that asap! you can get SO much better for less. If you want to brand match you can go with two audioque SDC2.5 10s for $129 a piece with an AQ1200D for $249 or two type R tens which would be about $99 a piece and you could use the AQ1200D or find another amp in the classifieds. There are many different possibilities out there though so have a look see.
shawn76
shawn76
Canada
tc3k101
