Is this a good setup? Alpine + Sony + MTX
shawn76
Is this a good setup and will I be able to connect these subs to the amp bridged running at 2 ohm's? I've already purchased these items and hope to receive them in the next week or so. The system is going in a mid sized 4 door car. Hope I didn't screw up! Speakers will run off deck amp I guess. They are stock crap anyways. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Appreciate any feedback if possible. The reason I am asking is if there's something I should definitely "NOT" get, I can return the product if need be after it arrives.
Specs...
  • Sony Xplod TR2022 GTR Series 2/1 Channel Amplifier
    http://www.xplodsony.com/xplod/amplifiers/XM-GTR2022
    Class A/B
    600W x 2 Max Power Output
    202W x 2 into 4 ohms, 20Hz-20kHz, 1.0% THD
    Variable 50-300Hz Lo-Pass Filter
    -12dB/oct Selectable Slope
    250W x 2 into 2 ohms, 20Hz-20kHz, 1.0% THD
    Max Power (Watts): 1200
    Ad Hoc Power into 4 ohms, THD%: 202
    Ad Hoc Power into 2 ohms, THD%: 250
    Bridged into 4 ohms, THD%: 500
    Signal to noise ratio (dB): 93dBA
    Frequency Response (Hz): 5-50kHz
    Current Drain at rated output (A): 48A
    Width (inch): 15.8
    Height (inch): 2.2
    Depth (inch): 10.8
    Weight (Approximate): 11.4
  • MTX 10" Car Subwoofer (TC510) x 2
    http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10085244&catid=
    Mfr. Part Number: TC510
    Band Pass Volume Not Applicable
    Basket Material Stamped Steel
    Binding Posts Chrome Push Terminals
    Cone Material Expanded Poly
    Frequency Response 36-150 Hz
    Impedance 4 Ohms
    Magnet Weight 60 oz
    Mounting Depth 6 3/16"
    Ported Box Volume 1.45 ft/3
    Power Handling Max 900W
    Power Handling Nominal 300 Watts
    Product Warranty 1 Year Parts & Labour
    Recommended For Band Pass Not Applicable
    Recommended For Ported Yes
    Recommended For Sealed Yes
    Sealed Box Volume 0.75 ft/3
    Sensitivity Not Applicable
    Surround Material Rubber
    Voice Coil Size 1.75"
    Woofer Size 10"
  • Alpine iDA-X200 Head Unit
    http://www.alpine-usa.com/US-en/products/product.php?model=iDA-X200&lang=en&tab=F
    To much to list. Please see URL.
  • Other
    Bassworx 10" Dual Hatchback Sealed Subwoofer Box (SW210B)
    4 ga. Power Wire
    4 ga. Ground Wire
    18 ga. Turn-On Wire
    1 x 80 Amp Fuse
    Voltage Stabilizer
    etc...
lol sony amp and mtx subs...lol
Guess there's a problem with that since you feel the urge to laugh? Please enlighten me! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
you can't bridge the amp with those subs. you need dual 4 ohm drivers.with single 4 ohm, you'll only get the "rated" 202 watts x 2 @ 4 ohm per channel.
If you bridge it, thus seeing a two ohm mono load, it'll fry.
Thanks for the reply. So should I send back the subs (and look for dual 4 ohm ones), then keep the amp and deck?
keep the deck, return the amp and subs unopened, and do a little research. the classifieds are great on ca.com
Thanks for the reply. This is a nightmare haha! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
To save yourself some time next time ask before you buy. That way you won't have to wait while your stuff is being returned and then new stuff is being shipped to you. Also I suggest searching the classifieds on here you can find some great stuff.
shawn76
shawn76
Canada
tc3k101
