Is this a component speaker set & is it 3-way ????
IDriveCars05
This is my car. There are 2 speakers in the door. A Sub at the bottum of the door (kinda hard to see) and a tweeter in the top of the door. Inside the car, there is a 3rd speaker (i dunno if its a tweeter or what) in the left corner of the dash (TOP PIC). Is this a component set and is it 3-way????? I would really appreciate anyone who takes the time to reply. this speaker stuff is complicated bizz
The larger speakers located in the lower portion of your doors are 'woofers' or 'mids/mindranges', they are not 'subs'.
3 speakers per side in your factory front stage does not mean its a real 3-way system, chances are that its not. Especially with that mounting configuration. I agree with above, ditch the dash speakers and buy yourself a decent 2-way system. If you want to step up to a true 3-way, you need to look into kick panels.
Ok. So...if i buy a 2-way component speaker system, i should put the tweeter in the door (ditch the dash speaker) and that will give me the vocals i desire?
You would be best with that setup, yes. Like the one guy said, if you wanted to do a true 3-way setup then do the kicks. Otherwise a nice 2-way component set should do you justice.
you could go 3 way. im not saying you should, but you could.
Where on the dash is the speaker?
A lot of higher-end cars have a center channel. I test drove a Lincoln LS yesterday that had one. It made the music sound a little 'airy', not that it's necessarily a bad thing.
IDriveCars05
IDriveCars05
Silver Spring, MD
Bolognablake
