Is this a common practice for Midbass
Megalomaniac
Mr.SQ
Is this a common practice for a Midbass installation?
Installing the Focal K3P 3 way component set in front required locating the woofer somewhere other than the doors, so pods were built on the floor, with the midrange and tweeter mounted in the factory door locations. This is one great sounding system
04 corvette
http://www.caraudioinnovations.com/installations.htm
i dont understand as to why wouldnt they put the mid in the door and put the midrange in some kicks?...
they did it again in a 528 installation
I have actually heard of the midbass under the front seat area type install before. Apparently it actually works quite well and is done fairly regularly in European SQ competition. I believe the secret is not to run the midbass speaker very high.
i know suburus have a woofer under the set i think its only like 3.5" though. but i have never seen a pod like that where its completely in sight, and able to be stepped on.
You will note that it is only done with 3-way setups in a real SQ type install. I have heard of very high scoring European SQ cars using this type midbass location as long as the midbass is not ran extremely high it apparently works quite well.
that doesnt explain the tweets and midrange in the doors. cant be very imaged for SQ...
If for some reason they could not get a good install in/good amount of air space in the kicks... those midbass drivers on the floor like that are actually decent speaker placement.
Best Three-way installs I have ever seen with conventional drivers is mid and tweet in the kicks, and midbass drivers in the floor under the dash/firewall.... the midbass driver in an install like that, on the driver's side, for instance, would be under the pedals. maybe someone can post a pic of one of those installs, I know they are out there.
Megalomaniac
Mr.SQ
Megalomaniac
The Colony, TX
genxx
