Is There a Limit to Length of Slot Port?
  • 6
robert J
canada
I was wondering if a slot port has limitations other than the physical dimensions of the box?
In this case, the port needs to run to the back and across the width to the other side, leaving a couple inches before contacting the side panel of course.
It does but what you have is well within the limits
Multiple bends can also hurt output but it will still work it just could be better with a different port
Your port looks good
I assume this is for a 12?
You could always shrink port area slightly and it will get shorter. Or even use a round or aero port and that will help as well
I have read that AeroPorts can be a smaller area ratio/ft, even down to 5 or 6sqin.
Can you also extend the port outside the box a few inches to gain length?
Yes, it is for a 12" driver.
I have read that AeroPorts can be a smaller area ratio/ft, even down to 5 or 6sqin. Can you also extend the port outside the box a few inches to gain length?
we even had a guy extend his slot port outside of box..
there's a certain point where your airspace will get so diminished to where you actually start raising tuning instead of lowering, thats an extreme case but its always better to raise airspace over adding necessary port length and bends.
Hello, I am getting ready to install my 3000 watt taramps and 2 15s in an expedition. I am a little hung up because my old car had a 220 amp...
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
899
robert J
robert J
canada
Jeffdachef
    May 23, 2024
SPLBassJunkie
    May 21, 2024
