Is my amp set up wrong?
tohighpsi
md
Ok I went to a local shop to have my amp installed. I been busy and they were cheap enough. Everything has been fine with my system but today I noticed that my bass eq setting is not on 0. It is about a quarter of the way up. Does this mean that my gain was not set corectly. I dont have a multimeter to set it with like the gain tutorial says. What should I do? Can I get more out of my system. The amp is a bx1605d and a 15l7 wired down to one ohm. The gain is about 3/4 of the way up
Pre-out voltage?
Also, Bass boost can be used correctly in coordination with the gain knob, but a good system should not need to use the bass boost for daily bump, if at all.
tohighpsi
tohighpsi
md
tohighpsi
