is my amp performing up to its potential?
fasteddie03M3
i just installed a 1000/v2 JL audio 1000w monoblock with a 13W7 but it doesnt seem to be that great?!?!?! i thought these were award wining subs. but i did not do any upgrades such as big 3 and so on. could my amp + sub sound louder, be more powerful just from a big 3 conversion? anyone with before and after results please let me know if it helps in that sense. thanks
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif:rotflol://content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif:rotflol:
Its sad that people go ahead and buy JL, get sucked in by the local shops, and then come here AFTER to try to peice together there mistakes.
And I guess to keep on topic. Your car should handle 1000 watts just fine without big 3, are you using 0 gauge wire? If not then id definatly upgrade. My truck has a 130a stock alt and held 1000 watt system with all 0 gauge wiring and big 3 NOT done, never dropped below 12 volts..at full tilt it would go to low 12s. But then again, even if your dropping and losing say..200 watts, it wont magically get louder from those extra 200 watts.
did I? How so? enlighten me pilgrim.
...You thought jl was "award winning subs" apparently, means you thought they were some hot shit, and they didnt live up to your expectations. Did you get a prefab box aswell? Browse thru the forums for a few hours alot of great info to be had. Might have to weave through the BS tho.
realy? is that so sad? if your so intelligient, why dont you explain thesis chap
look bud...the shit is loud ok. just not punch in the face loud LIKE MY FRIENDS jl 13w7 set up he had a few years ago. so are you meaning to tell me that...... my amp is running at full capability of my stock ground+poss with no upgraded batt alt or cap?
Looks to me as if OP drives a Beemer. Hatch or trunk? If trunk, back seats up or down? BMW has very good insulation for the trunk, and that may be part of the problem.
I had an old 89 325 it had a sheet of metal behind the backseat had to take a sawzall to it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
not trying to be a jerk or anything but if you know this why make this thread?
That amp is gonna put out about 1000rms from 11v-14.4v, so doing the big 3 will not make anything louder..
What kind of box do you have...thats about the only option you have with that setup...
so it means absolutely nothing that my lights are dimming at 1-3 of the vol up?
fasteddie03M3
fasteddie03M3
Syracuse, NY
jon_k
