is jl audio slash 1000/1v2 amp powerfull enough to run 3 10'' w6v2-D4subs?
^^ Yeah thats what I was going to recommend if he wanted 1500rms, look for the rockford t1500bd-cp, those are underrated and you should get close to 1300 - 1400rms at 2.67 ohms.
sorry but im confused now cuz with slash 1000.1 around 350 rms to each sub is not that satisfactory for me cuz the subs are 600 rms each..i wanted to put atleast 500 in each..im already goin with sealed box..i think i have enough sq already since they are W6s ?? i need some loudness too you know
see guys like these confuse me. 2 of you are saying slash and 2 saying hifonics..what do you say about jl audio's hd1200 it has a bit more power..?? is it is as efficient as slash 1000.1 ??
they could be perfect for my system if i had $1500 for 3 jl slash 500/1 amps
---------- Post added at 10:41 PM ---------- Previous post was at 10:40 PM ----------
i can still return 3 10's and get 2 12's ..you think i should do that ?? will i notice alot of diff in 3 10's or 2 12's both w6v2 ??
i have space for 3 10's or 2 12's but in a sealed box..since w6s are not that thumpy and with slash 1000,1 i dun wana underpower them..i wanna get most out of my subs 350 rms each is nothing
JL, Kicker, Fosgate and a few other amps are underrated. The reason I'm telling you it fine is the 1000/1 puts out atleast 1200 watts. If you can get 2 12s ported I would do that. But understand the W6 does not get that loud as say a Alpine type R or MANY cheaper better subs. They are made for Sound quality not output. If you are fine with that any good name 1000 watt amp at 2 ohms will be fine for them.
Skip the Slash Series, too expensive and very inefficient. I would go with the maybe an Alpine M12, which is a bit expensive, around $500, but would give you the power you want, even with the weird ohm load. And thats a new price. Or even an Alpine MRP-M2000, which would give you 2k @ 2 ohms, which with the 3 ohm load you have, and the gains a little down, would be very sufficient! It can also be had new for about $425.
Those are just some ideas. Of course you can get the same amount of power from some cheaper (less expensive amps).
Saini.Preet
Saini.Preet
Brampton ,Toronto
THATpurpleKUSH
