is it normal for amps to get warm
guys wrong section to be trolling on a girl. and how the hell does she make her posts bold?
You mean leik dis?
OP if the amp is getting hot that means the heatsink is doing its job by dispersing heat. On the other hand, that also means that the amp itself is getting quite hot. Low voltage and low impedance will do this. If your amp is getting quite hot to the touch you need to do something about your electrical system, or use an amp that uses better components that won't heat up as much
You mean leik dis?
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Just a FYI ecrack(and no hating here)
When outside the dome that sig/name may net a negative result per forum rules.
I thoroughly read the TOS and rules prior to posting with them. If you can show me what I'm in violation of I will change it. I found nothing.
I think the loop whole as always is that a mod can intemperate them differently as any of us can. They are also subject to change with out notice. I would assume those are going to be the issues overall.
Another could be that they could consider them to be "provoking" in nature and that could cause a vacation all though I would think they would just ask you the change them first.
113
398
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
mdsniper7
mdsniper7
tampa fl
fish1234
    May 12, 2024
Brendon Jenness
    May 11, 2024
